Does anyone know how to print a markup summary to PDF in column form, but not have the (1) designation on any of the selected columns?
@Christopher Castro, You can achieve this by applying a filter during export. Assign the items marked with “(1)” to a specific column, then either uncheck that column during export, or exclude them during the filter and sort stage.
Hope this helps!
@Shaya Birnbaum I think the (1) is a count BB adds to the list, not part of the "subject" like it could say Line (13) and then list thirteen line markups. Below is an example (different format) of (7) markups by "lshiras". Later there will be (29) markups by "Luke Shiras"
@Luke Shiras, Thanks for the clarification. I usually export to Excel, so I haven’t encountered this issue before. I tried manipulating the PDF export, but regardless of the setup, it still includes a “Total Count” heading. This problem doesn’t occur when exporting to Excel.
When I am trying to search for keywords on a plan/document, it displays 0 results found. This is the first time I've had this problem. Does anyone know why that would be?
We are currently reviewing our licenses and find that we lack the necessary functionality to scale up or even maintain our current number of licenses. We would like to see functionality for creating and managing templates for control plans, commissioning protocols, checklists, and similar field documentation, with results…
I hope that is what the feature is called that I am referencing. I have used Blue Beam now for a couple years. I have always used the Line and Polyline tools when drawing things, especially overlays to buildings where I want to keep nice straight lines. In the past, I could select the tool, let's use Polyline: if I held…
Is there an easy way to create a hyperlink from a sheet number, such as C-400, that jumps directly to another sheet (for example, C-500), and then have C-500 include a link back to C-400?
