I am trying to delete a previous session and entering a new one. I keep getting an internal server error. Does anyone know who to get a hold of to fix this?
Same. It looks like https://status.bluebeam.com/ was updated with
We’re currently looking into issues reported on Bluebeam Studio. We’re sorry for any inconvenience. Subscribe or check back here for updates.
My entire organization is also experiencing the same error. I submitted a ticket and checked the bluebeam service status page but it doesnt say if this is a known issue.
