知っている方が居たら教えていただきたいのですが、図面を翻訳する機能はありますでしょうか?
よろしくお願いします。
Seems as if @Doug McLean has a story about using Revu to translate some text @haradaai. Perhaps he can answer your question.
The question:
If anyone knows, please let me know if there is a function to translate blueprints? Thank you in advance.
Yes, there is a translate markups function built into the Markups list. Highlight what you want translated, go to the Documents menu and select Translate Markups.
The text will change in the Markups list and will show that text in a bubble when you hover over the highlighted text.
Thank you for chiming in @Doug McLean!
Do you know if there is a way to translate the PDF content?
it will only do the text. Google Translate is only so good.
@haradaai Bluebeam Max Beta に参加していますか?MCP と Anthropic Claude を使って PDF の内容を翻訳する使い方があります。こちらは、弊社のプロダクトディレクターが見せてくれたデモ動画です:
So this means a translation with only markup, right! Thank you very much.
