How do I show a file path in a text box?
Copy the Filepath from Windows Explorer and then Paste. It won't link though, you'd have to add that back as a hyperlink
I'm not sure how you dynamically do this with a Text Box but you could do it by using &[Path] within a custom Stamp.
