When I am trying to search for keywords on a plan/document, it displays 0 results found. This is the first time I've had this problem. Does anyone know why that would be?
You may have a "raster" or scanned PDF @Mike Bond?
You could try running the Batch OCR (optical character recognition) to see if that helps Revu see the text.
Hope this helps. 😎
Select "OCR" under the "Batch" menu:
How do I do that?
