Can Bluebeam convert a .pptx file to a PDF, and if so, how?
@bmarchitect I'd try right clicking on the file in the directory and selecting "open with" and choose Revu.
Not sure if it will work, but it's worth a try…
If it does work save it as a PDF from Revu.
Hope this helps. 😎
Thanks for the suggestion, but it didn't work.
It was worth a try!
@bmarchitect I probably should have asked what your end goal is. If you have the .ppxt file couldn't you open it in PowerPoint and then print it to a PDF?
I suppose you could, but I don't have powerpoint. I'll get a friend to try it. Thanks for the help.
Use the "Print to PDF" option in PowerPoint when you Print. I use that approach all the time.
My preferred method in PowerPoint is File>Export>Create PDF/XPS Document. I like this method because the created pdf pages are limited to the slide dimensions, and you don't end up with odd borders around your content.
