i cannot see my properties panel. it only shows up if i change profiles. i cannot use shortcut key Alt-P to make it visible
on the other profiles make sure its not pinned to the other side or the bottom. Kinda weird that it's not showing up actually
@MikeP if you right click in the left panel area and select "show" do you see the Properties Panel listed?
If you see it there and click on it Revu should display the Properties Panel along the left side of your screen.
Typically I run with my Properties Panel "undocked" on another screen. Sometimes, if you are working from a laptop that you had an additional monitor hooked to it some of the undocked panels might still think that the external monitor is there, even when it is not…
Hope this helps. 😎
So true. I try to make sure I reattach the three panels I have on a separate monitor before I close down the program.
