I have a document with over 30 text boxes that are polygon shaped. I need to keep the text the same and just change all the text boxes at once to a rectangle shape. Is there any option to do this? Any help would be greatly appreciated.
As mentioned, the selector disappears with multiple markups. One thing you could try is to change one of the hexagons to the shape that you'd prefer. Then, right-click the new shape and choose Format Painter.
Your cursor will become a paintbrush. You will be able to click the remaining shapes and have them change.
Here is a visual of what I'm working with.
I was going to say "Select them all in the markup list" but if you pick more than one, you can no longer change the shape. 🤔
Unfortunately, I tried all methods I know of to select multiple markups and once you select more than one, the shape selection option disappears. This would be a good suggestion for improvements to REVU.
I have never noticed this in the right-click menu and I have been in there a million times!
