I am using version 21.6.1, and my dynamic fill is deactivated. Pls let me know how to activate dynamic fill.
Thanks
Unfortunately @Srinivasan "Core" does not include the Dynamic Fill feature.
Go to Revu > About. See what version you have. Dynamic fill is unique to Complete.
Hi Ken, thanks for responding - This below is my Revu>About
Does this version of Revu have this feature
That Explains David - Thanks Much
