Hi, how do i add or create a coverage area layover similar to this and scaled …Thank for any help
@LD166, the design is an intricate one, first you will have to either create the design from scratch or use the screenshot tool to create the design.
Once that is done, scale it to the correct dimension you want, add it to your Tool Chest, and make sure to click Set Scale.
