Sometimes right click will drop it, but most times I must select a new tool before escape will work. and no, my reuse markup tool is not engaged when this happens.
I've experienced this too from time to time. I think it's just a quirk of some tools to need overridden instead of just being backed out of. I could be wrong about that, but I have most of the common tools set to keyboard shortcuts that serve me just fine so I usually just choose the next tool and keep going anyways. Could you tell us which tools you've experienced that with today?
When it gets sticky, all tool types refuse the escape key option. If it gets particularly stubborn, I save all that is open and reboot Revu. 3 out of 5 times that settles it. Where it's particularly burdensome is when I want to type into the placed markup. The cursor won't appear until I've dropped the sticky tool.
I just don't know how to replicate that. The only time I've had even a little trouble with a tool getting stuck, I just needed to hit the hotkey for another similar tool and it would let go of the one I was stuck on. When that didn't work, I might end up crashing Bluebeam, but the doc loads back up with the backup version. Never been a big issue. Have you reached out to Bluebeam's support directly?
Thank you for getting back to me. I tried to find that support option unsuccessfully. Is how I ended up trying this route. Please advise on how I might connect to that service. This issue has an impact on productivity and the workarounds are tedious. I love the functionality Bluebeam offers to our production team, just wishing I could move a bit faster with it.
You can find tech support in the app. Go to Help > Technical Support. Then you can search for your issue or go to the bottom of the page and select 'Submit a Ticket'.
I've always been pleased with Bluebeam's Support team. Maybe someone else will swoop in with an answer, but this is the best I an offer with my experience. lol
When using the highlighter to mark completed changes, it often jumps into "text" mode every time it goes over letters, etc. Is there a way to turn this off so I don't accidentally highlight a bunch of text? I know you can hold down the CNTL button, but I'd like something that works more smoothly.
I am interested in understanding how my team can utilize BBM in the field to perform construction punchlist with notes and pictures and how this data can turn into report. Ideally we would like to have a toolkit available. What is the timeline for this functionality?
I am trying to get or develop a way how I could get an automatic distance between two devices taking into account some parameters that I define
If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added…
I'm using the mobile app for iPhone and my project recently stopped updating all the changes I make on my laptop. I'm currently running back and forth taking pictures of different details and going back to the building to layout work for my guys. Is anyone else experiencing this issue? I hope it's something really dumb…
I am open to purchasing a higher license, but first I want to see if this will work like I am hoping it will. My company adds user data in a spreadsheet (e.g. IP Addresses, SN, etc), and we would like that info to go directly into our as built drawings. The idea being that we would only have to update the information in…
I am looking for a way to organize my existing layers on a project that I am working on. I have yet to find a way to move the layer to a sub group. In this example I would like to move all my overlays to one group (Overlays would then contain Power, HVAC & Roof).
I seem to have quite a few tools that are not accessible. How do i activate them?
I drew two lines and want to measure a distance from the intersection of the two lines to another point, however, I cannot seem to find where the snap controls have been moved to in BlueBeam Revu 21.8. For reference I have snap to content and snap to markups both enabled.
What are these numbers used for starting from 1 to how many mark-up tools you have, as per below 1-8? it's not on any other mark-up tool in my Tool Chest
