If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added every markup that I needed to reuse to the Toolbox, then the Toolbox would become impossibly large and cumbersome and contain many Tools that were only ever used on one project. Surely there is a way to do this without manually setting the properties on the new takeoffs?
