I seem to have quite a few tools that are not accessible. How do i activate them?
A good question @Alan Priestley. I'd suggest starting by ensuring that you are logged in by clicking on your user name at the upper right corner of your Revu screen:
After that you should look at your plan - not every tool is available with every plan level.
Check this and see if this helps get you access to more tools.
Hope this helps. 😎
@Alan Priestley, in addition to @David Cutler mentioned, it is also possible the document is locked/protected, which would limit tool availability. Try opening a different document or creating a new blank sheet and see if the behavior changes.
If you need help unlocking a document, check this out:
Good point @Shaya Birnbaum! I hadn't considered the potential for the document being locked…
