Do you know of an integration between Bluebeam and Procore that allows Bluebeam to mark up plans and sync to Procore? Thank you
Vinnie Seattle WA
@Vincent ProCore does indeed make an integration with Bluebeam. As of today, it lists as "Coming ****" on our Integrations Site, but that is just because they are just completing their upgrade from our old API endpoints to our new, easier to use API endpoints.
If you check out the ProCore website, it shows that their Bluebeam integration is available, but in Beta (because of the switch to our new endpoints).
Anyhow…. long story short: There is an integration that lets you push your drawings/documents from Procore into Bluebeam Studio for markups and communication and then it round trips your documents back into ProCore when you're done. All you need to do is reach out to ProCore to get the details!
Thank you Nate,
I will let the client know.
When using the highlighter to mark completed changes, it often jumps into "text" mode every time it goes over letters, etc. Is there a way to turn this off so I don't accidentally highlight a bunch of text? I know you can hold down the CNTL button, but I'd like something that works more smoothly.
I am interested in understanding how my team can utilize BBM in the field to perform construction punchlist with notes and pictures and how this data can turn into report. Ideally we would like to have a toolkit available. What is the timeline for this functionality?
I am trying to get or develop a way how I could get an automatic distance between two devices taking into account some parameters that I define
If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added…
I'm using the mobile app for iPhone and my project recently stopped updating all the changes I make on my laptop. I'm currently running back and forth taking pictures of different details and going back to the building to layout work for my guys. Is anyone else experiencing this issue? I hope it's something really dumb…
I am open to purchasing a higher license, but first I want to see if this will work like I am hoping it will. My company adds user data in a spreadsheet (e.g. IP Addresses, SN, etc), and we would like that info to go directly into our as built drawings. The idea being that we would only have to update the information in…
I am looking for a way to organize my existing layers on a project that I am working on. I have yet to find a way to move the layer to a sub group. In this example I would like to move all my overlays to one group (Overlays would then contain Power, HVAC & Roof).
I seem to have quite a few tools that are not accessible. How do i activate them?
I drew two lines and want to measure a distance from the intersection of the two lines to another point, however, I cannot seem to find where the snap controls have been moved to in BlueBeam Revu 21.8. For reference I have snap to content and snap to markups both enabled.
What are these numbers used for starting from 1 to how many mark-up tools you have, as per below 1-8? it's not on any other mark-up tool in my Tool Chest
