Hello - Does anyone know of any companies that review the quality of construction drawings prior to construction? Any that utilize AI? Thank you!
A few pop up on search results, but not personally, best I have unfortunately. In the search I did for the best reviewed companies, one did pop up that use AI algorithms, although I do not know the accuracy
AI has a little trouble with drawings for now, too scattered for it to make sense of the drawings, but there are a few companies that offer Design Review services.
I appreciate the response. Wondering if you know which companies?
You're awesome. Thank you!
Why in this new version the command "offset" is disabled? It saved me a lot of time. How can I enable it again? My Revu plan is complete
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
