Is there a way to select all items on all pages after mark-up? I need to have all items appear, from all sheets in a single legend.
Common mark-ups will all tally together, but if there is a stray item on a single page, it gets left behind.
I don't think that's a thing really. Could you maybe place duplicate mark-ups on the sheet with the legend, but just outside the printing area so the markups aren't "on" the drawing but they're still captured? I'm spit-balling here and not totally sure that would even work at all.
Go to your markup bar and multi-select (can just hit "ctrl+a" to select all markups in the bar) right click, add to legend
For the source of the legend are you selecting "All Pages"?
ugh I hate the placement of this setting, it took me so long to find it in the properties panel
Yes, I am. If a mark-up does not appear on the current page, it gets missed from the legend
Tried that. "Legend" is not selectable from there.
Should show on right click, just out of curiosity, what version of revu are you on? Is it any specific type of markup that's not populating?
And the first attempt the legend was created from the toolchest the tool came from? are you modifying any properties of the tool? i.e. changing the subject? Here are some snapshots of how it should normally be applied, how you would select the source, and also how you would manually add things to an existing legend. If all this is broken and you are on the latest version, you may need to re-install, but I have a feeling there is a detail were missing here.
Legend is not selectable.
REVU 21
I would like a .BTX file with all Electrical and AV Symbols in it. I would like to mark up plans for material Takes.
If you choose an area and set the color, line weight and so on, then click out of measurement you have to then go back and redo all the particulars for that item that you are trying to take off. Can this be remedied? Onscreen allows the user to set a group of items to use repeatedly throughout a set of drawings (color,…
Curious if anyone adds a "time" or "man hours" columns in their markups list when doing takeoff. I have some ideas but unsure if they will actually be useful. For example: 10 LF of footing = 1 man hour. Does anyone have any tips on adding custom columns on their markups for time? I already utilize it for material cost per…
Our company used bluebeam studio on the USA server before we had access to AU licensing. Now we have all AU licenses logging in to the USA studio server, and it tangles itself every day (worse with azure AVD). USA studio login seems to time out and when I log back in it removes the login to the AU license and logs in a…
Good Morning Has anyone successfully imported their take-off from Bluebeam via excel into Trimble Contract Master Estimation software and have you managed to link an item in that take off to your database item?
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad?
Hi!, I'm a senior technician in an architect office, and I regurlarly do some site surveillance and dificiency reports. I am looking for an app on a tablet to consult plans (pdf format ideally), annotate them with comments (ideally speak-to-text) that will generat a list of comments with a "pin" on the pdf plan localising…
Imagine placing a door symbol and Revu automatically attaching a mini BOQ for leaf, frame, hardware and labor, all rolling up into one smart cost object that updates as you copy or move it.
