I would like a .BTX file with all Electrical and AV Symbols in it. I would like to mark up plans for material Takes.
@dclinton here are a couple of places to try:
Bluebeam's site has some tools that might get you started: https://support.bluebeam.com/revu/resources/revu-custom-libraries.html
@Troy DeGroot has a huge library of custom markup tools available on his UChapter2.com website: https://uchapter2.com/resources/free-downloads/bluebeam-tool-sets/
Hope this helps. 😎
Thanks thats what im looking for.
