I use custom stamps regularly and find panning up and down in the dropdown to be annoying since the icon to pan up or down is so small and when my pointer goes past it the drop down disappears, then I need to find my stamp again..!
Please fix..
It would be nice to have a easier scroll feature. Here is another crazy example to help bring most used stamps to the top. Name the stamps you use the most with special characters (++, +, - ….) to give another depth to the alphabetical order to your list.
Another option they could add is to add subfolders for related stamps
I was just about to make a post about this. I think having subfolders in the Stamps and Templates dropdowns would be a great way for companies to organize their standard tools.
In Bluebeam Revu I'm used to working with multiple files open and switching between the different tabs. Is this possible in the new Bluebeam without constantly having to close and save the file to open another?
I have BB Revu 20. I had it set up where on the RH side of my screen i had selected certain idk what the term is for measuring, font colors for when i use the measurement tool, the line tool where one can change the font and fill on a cloud for example as well as other items. I lost that tool bar that was on the RH side. I…
Is there a way to list all markups made since the last file save?
Hey - hope someone can help me here. I have custom mark ups I "save" to the tool chest to a custom tool set. When my session ends and I close and reopen bluebeam - none of the saved tools reload. Example - I am marking up an electrical plan. Realize I don't have a markup for bath fan with light. I create a custom mark up,…
Is there any way to autogenerate markups in Bluebeam instead of manually tracing every area and perimeter? I bid multiple jobs a week, and these "robotic" takeoffs are a huge bottleneck. Does Bluebeam have an AI feature to auto-detect these boundaries and generate the markups? Manually tracing miles of sidewalk, asphalt,…
Acting as the owners representative I would like to be able to to walk through our projects with an Ipad in hand, open to our drawings; mark up the drawings, tag the mark up with a picture and description in efforts to issue as a "deficiency report" to the construction team. We would hope to use this to create a site visit…
I have recently begun using Bluebeam projects to test out the functionality when going from the office to the field and trying to take advantage of "one uniform set" that the Projects feature offers. Last week I've run into an issue where on my iPad, the file I am using in Proejct gives the message "Unable to Open…
Hey guys, I have an excel template I use for take-offs. While on the spreadsheet, when I set the source file to the drawing, there is a very small chance that it successfully links. Usually, I have to set the source file, nothing happens, so I then set up a new quantity link. When i setup a new link, all the other quantity…
I'm trying to fill out some ITB Documents with BB but whenever I create a new text box and then type in the text box my space bar does not work. This just becomes a long string of words. I have tried to uninstall and reinstall the program but the issue remains. I never had this problem previously, and have been running BB…
When I am working with multiple pdf files, I have to extend one or more files to the second monitor. When a pdf is brought to the second monitor, the Bluebeam ribbon and menus will not go along with it to the second monitor and I will always have to select the tools from the original bluebeam window in the fist monitor. In…
