hello I'm new here. I am needing to use this program to find the square footage and the baseboard perimeter of a project that I'm bidding on and I have no idea how to add it to the app or how to make it work. Can somebody please help me?
Do you have a screen shot of what you're trying to accomplish? Might I suggest watching a few videos at Bluebeam University first before you start getting into using the software. It'll help
@HollyTalbot , switch your left side panel to thumbnail views, then right click on each plan you are working with and set the scale. Hopefully they are one of the PRESETs that are typical architectural scale settings, otherwise, you can use the CALIBRATE command (second one in the pic below). Once you have scale set, all these icons will provide measurements and values for your takeoff. Examples are the POLYLINE and the POLYGON that will give area and perimeter.
Follow these links to get started after setting the scale. Area tool: https://support.bluebeam.com/online-help/revu20//Content/RevuHelp/Menus/Tools/Measure/Area--MTV.htm Perimeter tool (Core and above): https://support.bluebeam.com/online-help/revu20/Content/RevuHelp/Menus/Tools/Measure/Perimeter--MTV.htm
The area tool will actually accomplish both. While the Area tool's primary measurement is Area, it gives other dimensions as well.
The Length of an Area markups is actually the Perimeter, plus it also will give you a height and a width.(just remember that the height will always be on the y axis and the width will always be on the x axis)
As you can see, if you set up your markups list properly, you can actually achieve both of your goals with one markup.
When using the highlighter to mark completed changes, it often jumps into "text" mode every time it goes over letters, etc. Is there a way to turn this off so I don't accidentally highlight a bunch of text? I know you can hold down the CNTL button, but I'd like something that works more smoothly.
I am interested in understanding how my team can utilize BBM in the field to perform construction punchlist with notes and pictures and how this data can turn into report. Ideally we would like to have a toolkit available. What is the timeline for this functionality?
I am trying to get or develop a way how I could get an automatic distance between two devices taking into account some parameters that I define
If I measure some items several times, and then an hour later find some more to measure, can I reuse the markups I used initially without adding to the Toolbox? I see there is a format painter but this just changes the markup appearance without changing the markup properties such as layer, description, etc. If I added…
I'm using the mobile app for iPhone and my project recently stopped updating all the changes I make on my laptop. I'm currently running back and forth taking pictures of different details and going back to the building to layout work for my guys. Is anyone else experiencing this issue? I hope it's something really dumb…
I am open to purchasing a higher license, but first I want to see if this will work like I am hoping it will. My company adds user data in a spreadsheet (e.g. IP Addresses, SN, etc), and we would like that info to go directly into our as built drawings. The idea being that we would only have to update the information in…
I am looking for a way to organize my existing layers on a project that I am working on. I have yet to find a way to move the layer to a sub group. In this example I would like to move all my overlays to one group (Overlays would then contain Power, HVAC & Roof).
I seem to have quite a few tools that are not accessible. How do i activate them?
I drew two lines and want to measure a distance from the intersection of the two lines to another point, however, I cannot seem to find where the snap controls have been moved to in BlueBeam Revu 21.8. For reference I have snap to content and snap to markups both enabled.
