Just wondering what everyone is using in the field other than an IPad? Any Galaxy Tab, etc. users out there? If so, have you got any feedback?
Tried using microsoft surface but it's not user friendly. went with ipad instead.
Thanks for this feedback @owen_archmill !
Ipad for the last 8 years.
Thanks @Joel Glanton !
I've been using a Dell 7320 Detachable for a couple of years. The active pen worked well until I lost it. Still need to replace that . . . . I've never used Bluebeam on anything besides Windows, so I don't know if iPad versions work differently or better than what I describe below.
Anyway, I typically use it in full tablet mode while in the field. Bluebeam works decently for me, but it requires some setup to get it right. I use "Full Screen" mode most of the time and laid out the floating toolbar with my most frequently used tools and some other important ones like "save." It's also important to have some good toolboxes e.g. I have electrical devices in a toolbox and I can mark approximate locations quickly as I go.
While it is possible to mark things to exact scale, Bluebeam does not work well in touch mode for that—drawing a dimension or object displays the floating "height" "width" "rotation" dialog.:
At my desk, I can hit the "tab" key and type in exact numbers. There's not really an analogous action on a touch screen. As a result, I tend to place non-scaled objects approximately and put exact dimensions in the item's note.
Text input is tricky. The Bluebeam handwriting recognition does not work well for me, so I like to tap in text/input fields to get the Windows touch keyboard and type that way. You can also just use the pen tool to write directly on a drawing. My handwriting is too awful for that to work very well for me. It could be great for other people.
Photographs can be added in two ways. You can capture a picture and lay it directly on the drawing (messy if you have more than one) or you can capture into the note for an object. With the latter, Bluebeam displays a small camera icon near the notated object. Clicking it opens up the photos. It allows multiple captures as well, so you can take several pictures of the same thing and keep them hidden until wanted.
Most of my other frustrations are hardware related (the PC's camera is terrible, I feel the case is designed upside-down) and could be better with a different machine, but we take what IT provides.
The PC works well enough for what I need to do most of the time. Some things could be easier and some of that is taking the time to get the interface setup in better ways for my workflow.
Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out. Is there away around this Many thanks Murray
I've been trying to find anything related to this, but all I see is default tool 'settings' but I want to change the tool, not settings of the tool. The default selected now is the pan tool but my most used tool is the select text tool and when I open a new PDF or have multiple opened and then I close one, Revu will change…
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
When working on a file, Bluebeam will freeze then shut down. It's been happening quite frequently. Why is this happening?
As part of preliminary estimating for roadway projects I have created a custom toolbox for area, length and count items. I can change the color. Is there a way to change the icon to something like SW for sidewalk area? I have the measuring tools set up with custom labels and layers to facilitate review and quantity total…
Hello, Can I import Chets Tool Items from Excel. I've a list of items in Excel (number, description, m, m2, m3 of Pc) I've to measure. Can I import it to Tool Chest. Thanks.
Good afternoon, I want to create a Tool-Chest component in "Tool Chest" that automatically numbers, e.g., W001, W002, W003, W004, ... and measures the area. It should place this on the plan-view with number W001 and the area. And then also place this number W001 in the Marksup list so that the link between a specific wall…
Hello! Today when uploading a capture from a screenshot, the image sets at 3D, does anyone know how to make the capture images to set at 2D? Thanks in advance
Hi All, I want to send selected sheets from my drawing Set to a sub contractor. Is there a way to send just the sheets I select from the Sets window? Thanks Ahead, Ian
