Hi All,
I want to send selected sheets from my drawing Set to a sub contractor. Is there a way to send just the sheets I select from the Sets window?
Thanks Ahead,
Ian
You probably need to print the latest Rev to a new PDF and then do your selection from there.
There are a couple of ways to do this.
Open all the files you want to send in different Tabs. The simply combine all the open files. If you know their file names, you can also do this directly from File Explorer.
