Is their any way to import a "standard list" of measurement items that I could use on multiple projects without having to type them each time I start a new project. I.E. is their an import function that could facilitate this need?
Welcome to the Community @BJL!
Short answer - YES! You can create custom tools and reuse them on future projects.
The next question is how much detail you want to collect with each markup and how you want to use the information in your overall workflow.
To get yourself started create a custom markup. Once you have the properties set the way you want select the markup, right click and select "add to tool chest". That tool will now be available for all future projects!
If you are new to Bluebeam there is some great content available on the UChapter2 YouTube site (https://www.youtube.com/@UChapter2 ) and the Vinic Surveying YouTube site (https://www.youtube.com/@vinicsurveying )
Don't forget to check out Bluebeam University too!
These are great places to see what is possible with Revu.
Hope this helps! 😎
Good afternoon, I'm dealing with plans where every page is a differant scale. When I switch the scale on a differant page, it changes qunatities for all pages. I tried using viewports but it won't show me the total rollup on the bottom of the whole project. Any ideas? Thank you!
Is there a way to view two open PDFs side-by-side, at once? If there is, I can't find it. TIA!
Does the Mark-up Tools availabilty lag after renewal?
I recently updated to the newest software and my Bluebeam has been crashing daily. Has any one else experienced this issue? Are there any resolutions to this?
I am trying to purchase a license but I can't because while I am trying to check out the system asks me to sign in and this leads to unknown authentication error. What is that? I want to pay money.
Hi, I am wondering if I am the only one that has this problem lately. Why veiwing and editing plan sheets the program lockes up and I can't close it nor does it work any more. I have to end task it to restart it. This has happened several times in the last two weeks. Can anyone help me figure this out?
I created a new set with a set of 7 sheets; I then did slip batch to add 4 revised sheets. I saved that set file but then deleted it because I realized that it did not match one sheet (sheet name changed), but I would still like for that one sheet to supersede the old one with the same sheet number. When I go try to create…
Hi All, I moved some .pdfs in my studio folder around and that has wreaked havoc on the revisioning of my Set. Is there a way to remove the Superseded stamp and return the individual sheets to the current revision status? Thanks ahead, Ian
I run a Mac in my construction office. It is great, but the only point of friction is Bluebeam Revu. I have run Parallels with Windows, in the past, to keep Revu on my computer but (although it shouldn't) it inevitable slows the machine a little. I am currently using a sub-standard PDF viewer with limited construction…
