Is there a way to view two open PDFs side-by-side, at once? If there is, I can't find it. TIA!
Just split your screen. the Keyboard is either ctrl + 1(to open a copy) or ctrl +2 to open in a new tab. Or just use the icons on your Navigation Bar in the lower left hand corner. If you don't have a Navigation Bar, you'll have to turn it on Tools> Toolbars> Navigation Bar (F4)
Have both drawings open in Bluebeam then as Doug says, press CTRL + 1. This should leave you with both files open and viewable in a split screen.
If I split the screen vertically, I only get two views of a single document. How do I look at two separate documents in two separate windows?
Thank you, @Vince French and @Doug McLean CTRL + 1 worked :-)
