How do I change uploaded PDF doc from pending so that I can work on it?
I think pending means there is an update that needs to by synced. Are you working online? Has the PDF been checked in so that all changes sync up?
Good Morning ALl Just looking to get set up for further investing in my tool chest with symbols for Watermain, storm, and Sanitary symbols for when doing takeoffs for Civil construction. If you have any you would share or any iodeas it would be great. Unfrotunaltey not the best artist of the group, so freehand on the fly…
Why in this new version the command "offset" is disabled? It saved me a lot of time. How can I enable it again? My Revu plan is complete
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
