I have a new issue whereby every time i open Bluebeam, it creates me an additional "My Tools" chest….i now have 16 Tool chests named "My Tools"!?! They also cant be deleted so they are growing. Anyone have any ideas?
Probably you stored the profile in a different folder than the default Bluebeam is using (appdata/roaming). If you move your profile there and relink to that folder from the profile settings, these duplicates will be removed and everything works as normal. Hopefully this issue will be patched out soon.
Yes, this has something to do with the storage location if it is anywhere other than the default. Mine are stored in Dropbox so I'm encountering this. I've been in contact with Bluebeam Technical Support and they are looking into this issue. No fixes yet though!
Same here. Do you have any solution to this?
Although Bluebeam are working on this, there isn't an estimated date for when there will be a fix. Their suggestion is to save the Toolsets in Dropbox (or whatever you are using) but to keep the profiles in the default folder.
This isn't happening to mine, but I also have mine marked as "read-only" so it can't be accidentally updated.
So mine is saved on OneDrive (both my profile and tool chests), but on all of them I've right-clicked on the file —> Properties —> check the box next to Read-Only.
If you guys have your profile stored on Dropbox, OneDrive, or something similar, perhaps you can restore to an earlier version that isn't experiencing this, and then lock the file as read-only?
Thanks Liz. My problem is that I'm constantly updating so don't think I can save as read only. What I have been told to try is saving the Profile to the default location but the Toolboxes to Dropbox - not tried this yet though.
Hi. I've been having the same issue. Our profiles were saved to a drive on our network, not the default on our PC local drives. I've just re-routed everything back to the default folder on my PC and it's partially fixed the issue. When I open the profile now there are no extra duplicates created, but the ones that had already sneaked into the profile I'm currently using are still there, but at least now they remain unchecked so don't keep showing up as open tool sets. BTW, I've reverted back to 21.5 for now. I've not heard anything from Bluebeam to say they've fixed 21.6. In fact, I've heard nothing from Bluebeam despite numerous attempts to get some answers.
They have not fixed this specific issue, but they are aware of it and have been able to recreate the problem.
What do you mean by "constantly"?
If it's once a week or less, I think marking it as read-only would be doable. You just uncheck the read-only box, then Save Profile, then check the box again. It's not too bad.
But if it's multiple times each day, that may be an issue. But, at the same time, if it's that frequent I'd wonder why and if there's something you can do to minimize needing to update it so often.
It depends on which profile I'm using.
Some such as that for measuring retaining walls basically never get changed. However, those such as the one for measuring brickwork are changed for things like where I change the weight of custom line styles to suit the scale of the drawing being measured. I'm back to using the defaul location at te moment and will move everything again once a fix is found.
Is there a way to batch hyperlink a range of pages instead of the entire document? I have a 325 page document. Within that document are sets. There is an overall page with area references to that set. That set is page 58-78. I know I could pull the set out and do it, then reinsert. Just wondering if there was an easier way.
Are we ever going to be able to edit a user email address in Org Admin? I know this has been discussed before and was a topic at Unbound last year. I have heard nothing about it since. This may not be a frequent issue, but it has come up several times now with users who have changed their last name. Our organization email…
Hi, Im locked out of my account. Could you please reinstate my account as we have made payment and I have been on hold on the phone for an hour today and 30 minutes yesterday to no answer and i can't get through to you via email. Thanks,
