Is there a way to select all items on all pages after mark-up? I need to have all items appear, from all sheets in a single legend.
Common mark-ups will all tally together, but if there is a stray item on a single page, it gets left behind.
I don't think that's a thing really. Could you maybe place duplicate mark-ups on the sheet with the legend, but just outside the printing area so the markups aren't "on" the drawing but they're still captured? I'm spit-balling here and not totally sure that would even work at all.
Go to your markup bar and multi-select (can just hit "ctrl+a" to select all markups in the bar) right click, add to legend
For the source of the legend are you selecting "All Pages"?
ugh I hate the placement of this setting, it took me so long to find it in the properties panel
Yes, I am. If a mark-up does not appear on the current page, it gets missed from the legend
Tried that. "Legend" is not selectable from there.
Should show on right click, just out of curiosity, what version of revu are you on? Is it any specific type of markup that's not populating?
And the first attempt the legend was created from the toolchest the tool came from? are you modifying any properties of the tool? i.e. changing the subject? Here are some snapshots of how it should normally be applied, how you would select the source, and also how you would manually add things to an existing legend. If all this is broken and you are on the latest version, you may need to re-install, but I have a feeling there is a detail were missing here.
Legend is not selectable.
REVU 21
Is there any way to autogenerate markups in Bluebeam instead of manually tracing every area and perimeter? I bid multiple jobs a week, and these "robotic" takeoffs are a huge bottleneck. Does Bluebeam have an AI feature to auto-detect these boundaries and generate the markups? Manually tracing miles of sidewalk, asphalt,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad? The image below is how you see it on Bluebeam for Web: The…
If you choose an area and set the color, line weight and so on, then click out of measurement you have to then go back and redo all the particulars for that item that you are trying to take off. Can this be remedied? Onscreen allows the user to set a group of items to use repeatedly throughout a set of drawings (color,…
Curious if anyone adds a "time" or "man hours" columns in their markups list when doing takeoff. I have some ideas but unsure if they will actually be useful. For example: 10 LF of footing = 1 man hour. Does anyone have any tips on adding custom columns on their markups for time? I already utilize it for material cost per…
Populous is hiring for a Computational Designer that sits on our Global Digital team. Link below to apply today! https://populous.com/careers?gnk=job&gni=8a78879e9c9ca640019cbacb46066ef9&gns=Recruiter
Hi!, I'm a senior technician in an architect office, and I regurlarly do some site surveillance and dificiency reports. I am looking for an app on a tablet to consult plans (pdf format ideally), annotate them with comments (ideally speak-to-text) that will generat a list of comments with a "pin" on the pdf plan localising…
Imagine placing a door symbol and Revu automatically attaching a mini BOQ for leaf, frame, hardware and labor, all rolling up into one smart cost object that updates as you copy or move it.
Is it possible to extract data from multiple pre-defined locations on hundreds of scanned PDF's and extract/export to excel? Scanned pdf's would have same form and locations of information. I have been able to extract all of information on pages (creates mess) but no way to capture just certain fields/locations?
Good Morning Has anyone successfully imported their take-off from Bluebeam via excel into Trimble Contract Master Estimation software and have you managed to link an item in that take off to your database item?
