I am trying to edit a comment made on a markup but I am unable to change anything. The markup is not locked. In the attached images are the 3 methods Ive tried.
Ah, that's the problem. You can't edit other people's markups. It's a common issue brought up here in the community. Depending on your workflow, you can add a reply and/or change the status, or add a new comment with the correction. You can also tell the author to fix it themselves but that's not always the most diplomatic approach. 😉
Are these your comments or someone else's?
@Luke Shiras someone elses
@Luke Shiras Thanks! Do you know of another way I could add a comment or note to the markup that would appear in the markup editor? Or am i unable to edit anything since I am not the author?
You should be able to create your own markups.
Is there anyway to customize keyboard short cuts for say the highlighter function? I would like to be able to have these for different colors.
Creating PDFS stopped working. Any ideas to fix?
I have a document that I have in Studio. If I open it on my ipad. Sign it. Save to file. Signature is not there when I open the file on my pc? Any ideas what is happening?
been getting a "file download error" on iCloud App. it wasn't an issue before but now some of the previous sessions is now not loading. it loads on desktop but not on the app. any idea what's causing the issue?
Good Morning ALl Just looking to get set up for further investing in my tool chest with symbols for Watermain, storm, and Sanitary symbols for when doing takeoffs for Civil construction. If you have any you would share or any iodeas it would be great. Unfrotunaltey not the best artist of the group, so freehand on the fly…
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
