I have hidden my measurements, or mark-ups, how do I get access to it?
It sounds like you might have some interface elements turned off? A screen shot might help understand better. Something you can try is to change your profile to a different one then back to the one you want. This can sometime "restart" the interface. Go to Revu (top left) > Profiles > pick any other profile that isn't checked currently
Then go back and choose the one that was checked previously. For example Revu > Profiles > Revu
Ken, tight at the bottom left it says Open PDF to mark up, how do I do it?
please help me to show the lengths of each measured item
Top left corner of the PDF will be a small toolbar to reference how many items you have hidden. Click it to unhide.
What is the pdf?, my tool chest is currently open and the drawings to the right of it. I used to have an arrow I think, to move the measurements wither to the bottom or under the options to scroll between pages, etc. Both of these are missing
THank I managed via google, it's in Windows - Panels - mark-ups
You can also right click on any existing panel icon the go to Show and it will list the menu of all the panels. If one doesn't have the blue shading behind it, that one is not currently displayed.
Glad you were able to figure it out.
Last night, our Admin team nearly lost their minds. While converting 92 Word documents to PDF, they discovered that the new PDFs were displaying the old versions of the Word documents. Any ideas what caused this and how to prevent or correct the problem if it happens again? They converted perfectly this morning.
What’s the Best Way to Measure LF on a Curved Wall?
Hi. Is anyone experiencing their toolsets randomly removing the first item in the list and replacing it with another? For example, I can open a set and the first one in the list should be say a 3-pole plug, followed by a 4-pole, 5-pole etc. but for some reason the 3-pole plug has been replaced by something random from a…
I have noticed when saving a file as PDF from Word the are sometime several bookmarks listed as "1". Bookmarks are created using Word headers, but there are never any headers named "1". Does anyone know why this happens and how to prevent it?
Is there a way to add together measurements between multiple pages? Say I markup a ton of items as MTL-2 over many pages; is there a way to add them all together? Like the legend below but for all pages with MTL-2
Just did the update this morning. Everything went well except I no longer have the Revu icon. It is just looks like a piece of paper with the right, top corner bent over. Is this the new icon or did something not load correctly?
I did not see this before but lately yes - when you click File/Email on any open file, the email window opening up will have the file attached but the actual file name will have [1] added to the name looking like ***[1].pdf while the subject line shows the original file name. How can I stop this so the file name does not…
I am needing to make comments/remarks on CAD-based file with a lot of layers and small symbols and when i try to select a group of my comments it grabs these - what appear to be random - cad-based linework that came with the original PDF. They have gray grips and i cannot edit those. I understand that I can turn the…
Previous to recent versions of revu, holding the control key while starting a measurement/markup or anything that would trigger object snap would temporarily disabled it. This is extremely useful when you generally want object snap on but not right at that second, usually because of a dense area where there are so many…
Is there currently an option to enable a new tab opening when clicking on a detail hyperlink? This would be great! Currently I just split the view and then click the link, but this seems more straightforward for new users.
