When I select the measure functions such as length, perimeter and area the background of the drawing turns blue. This makes it very difficult to measure and hides the detail in the drawing. How do I remove the blue background?
What version of Revu are you using @Neil Petrie? This issue popped up in Revu 21.7, but appears, base on what my teammates are seeing, to have been addressed in Revu 21.8. You might want to consider installing the update.
Hope this helps. đ
you MIGHT have a viewport. Go to your measurements panel and clear out all viewports if this is the case. You will see a list in the box about mid screen
I only say that because you said it is turning blue, otherwise go with what @David Cutler said.
Re-reading @Neil Petrie's original question I think you may be right @Doug McLean. Might also be an issue with the document being locked. Seems as if I've come across the "background turning blue" issue a few times where the documents were locked down.
I had the same issue - for myself, it was a viewport problem.
Once I deleted them all (they were all untitled) as per your instructions, my measurement tools were back to normal without semi opaque blue screen.
Thanks,
There is a black line that appears when converting from PDF to TIFF. It normally blacks out the title block but have had it black out parts of drawings recently. Is there any way to prevent this black line?
This might be a really obvious one but I can't seem to figure out the best way to do this: I frequently mark up drawing sets for estimates wherein there are multiple pass-through trades under my scope. What I want to do is to be able to do takeoffs for multiple trades, giving them each their own layer that represents them,âŠ
Need help with my cursor and measuring tools. My cursor will only go in a straight line in the measuring tool I am unable to follow a radius or use the measuring tool correctly, it will not follow the cursor but only go in straight lines.
Last night, our Admin team nearly lost their minds. While converting 92 Word documents to PDF, they discovered that the new PDFs were displaying the old versions of the Word documents. Any ideas what caused this and how to prevent or correct the problem if it happens again? They converted perfectly this morning.
Whatâs the Best Way to Measure LF on a Curved Wall?
Hi. Is anyone experiencing their toolsets randomly removing the first item in the list and replacing it with another? For example, I can open a set and the first one in the list should be say a 3-pole plug, followed by a 4-pole, 5-pole etc. but for some reason the 3-pole plug has been replaced by something random from aâŠ
I have noticed when saving a file as PDF from Word the are sometime several bookmarks listed as "1". Bookmarks are created using Word headers, but there are never any headers named "1". Does anyone know why this happens and how to prevent it?
Is there a way to add together measurements between multiple pages? Say I markup a ton of items as MTL-2 over many pages; is there a way to add them all together? Like the legend below but for all pages with MTL-2
Just did the update this morning. Everything went well except I no longer have the Revu icon. It is just looks like a piece of paper with the right, top corner bent over. Is this the new icon or did something not load correctly?
I did not see this before but lately yes - when you click File/Email on any open file, the email window opening up will have the file attached but the actual file name will have [1] added to the name looking like ***[1].pdf while the subject line shows the original file name. How can I stop this so the file name does notâŠ
