Is there a way after using the overlay command to go back an make edits or adjustments or do you essential just have to start a new overlay command?
@Matthew Avard, as far as I know the overlay itself cannot be adjusted. But there is a neat workaround. Instead of the overlay tool, try using the snapshot tool. Take a snapshot of the old sheet and paste it onto the new one. Assign it to a layer and you have your overlay. I usually colorize the snapshot so the differences stand out.
Hope this helps answer your question.
@Shaya Birnbaum thanks, I like this work around.
To add to @Shaya Birnbaum clever tips, when you paste the Snapshot, you can use Crtl+Shift+V to paste to the same location on the PDF in view as where it was copied from. Another tip, G is the shortcut key to SnapShots, Shift+G is the shortcut key to SnapShots without Revu Markups, just the authored PDF content.
Thanks Shanoc! I always forget about Ctrl+Shift+V. That shortcut could have saved me a lot of time!
Can Bluebeam Connect to Google Drive? I notice that Adobe can connect directly to Google Drive, but I cannot find an option for Bluebeam. I also checked the Google Play Store and did not see Bluebeam listed. Does Bluebeam support direct integration with Google Drive, or is there another method people are using to connect…
I know how to grant permissions from Revu 21 but can I grant studio project permissions from the cloud or app based applications or does it have to be strictly completed through the desktop application of Revu?
Hi everybody, since the installation of Windows11 and the last update Bluebeam, the comma button un the number field is not working anymore. in Excel, Word ect. he's working. Someone an idea
I can no longer copy/paste markups when using latest version 21.7
I'm not sure how long ago this changed, but it was pretty recent…. I used to be able to make a legend from my tool counts per page by selecting the counts to be per the "current" page and then at the begining of the document on the cover page I could create a Master Legend with the Total Counts that had ALL the counts from…
This morning I did a batch overlay with a set of over 150 pages. What I would like to know is if I can modify the alignment of pages once it has processed? I would like from it using page region to reprocess individual pages as auto alignment.
I would like to know if there is any information that explains the best use for overlay and compare in there own functions?
Hi all, I have reached out to the support team at Bluebeam with little success with an issue i am having recently. I have a selection of custom mark-up tools and columns that were created last year for the take-off of pipework and ductwork insulation and have been working well for the most part. As I carry out my ductwork…
I would like to know if there are any place I could go to download toolsets for doors?
