I know replies to text box comments are linked and show up in the Markups List. Is there a way to make these replies fully visible in the body of the document next to the comment?
The replies are visible when you hover your mouse over them, are thinking of some sort of toggle that would display them all at once, or would you want something darker/obvious?
Not sure if I personally would want the actual reply showing up next to the comment, but at least something that would make it visually clear (in the body of the document) that there is a Reply to that comment.
Why in this new version the command "offset" is disabled? It saved me a lot of time. How can I enable it again? My Revu plan is complete
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
