I'm having trouble getting batch link to work on my plan sets because it won't recognize a lot of the text. I've run OCR and this hasn't helped at all.
Any tricks to get this to run properly?
There is no substitute for bad drawings.
Make sure your elevation callouts are being recognized as text, otherwise, there is no real good fix for this. If you are creating the drawings, make sure that you are using a True Type font when creating. It'll makes a HUGE difference.
Hello, I'm having the same problem. When we run the batch link tool (using the latest version of Revu 21), some links are added, while others are ignored. In the attached screen snip, the blue links are created properly, while the highlighted text was missed.
All of the text comes from the same legend in Revit, using the TrueType font Arial-Narrow. Is this just a bug?
It looks like you're missing the screen snip.
So, I've encountered a similar problem recently. Basically, I was trying export some tables to Excel and a lot of the generated information was wrong - 2's became 9's, 1's became l's, etc.. To get over this I selected and changed the type of font. After exporting again, everything worked as it should have done.
Yes, I did! Sorry
Why in this new version the command "offset" is disabled? It saved me a lot of time. How can I enable it again? My Revu plan is complete
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
