Hi everyone, does anyone know why I have the Filter and Sort option disabled in the summary option?
If you go up to your login at the top right, and click on it, it will drop down and tell you your "plan". The filter and sort options in summary are limited to the Complete level only.
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
