I am very new to BlueBeam, I have managed to insert my Professional engineer stamp, I need to insert the date and signature on the stamp, meaning to layover the date and signature on the stamp in a certain area, and all should be visible.
Welcome to Bluebeam.
What you're going to need to do is learn how to make a dynamic stamp. There are videos and other tutorials on the subject, so it shouldn't be too hard to find.
The stamp will have a small amount of JavaScript in it, which will allow you to place those variables.
Good luck
Thank you Doug!
You can make the stamp without using JavaScript by using Dynamic Fill. Just add a text box to the stamp and choose "Date" from the "Dynamic" dropdown. See the example below.
Note: The date shown will be the date the stamp is applied, and it can't be changed.
Hope this helps.
Another thing to remember when stamping your engineer's seal/stamp onto PDF's is to double check what your regulatory body allows in regards to signing/stamping digital documents. For instance both APEGA & EGBC seem to recommend utilizing Notarius for their digital stamps:APEGA Digital SignaturesNotarius link for APEGA If you look under PRactice Advisor FAQ on the EGBC site (Specifically the 2nd point on sealing documents) reads:
"No, a scanned image of your seal, signature, and date, cannot be applied. However, the image of the seal can be scanned and applied to a document, which is then printed, signed, and dated. The legal requirement is that the signature is live.
For more information on sealing requirements please read the Quality Management Guides."
https://www.egbc.ca/registrants/practice-resources/practice-advice-program/practice-advisor-faqs I believe that you can still utilize Bluebeam for this - the signing registrant for our company manages it so if there's any confusion I can reach out to inquire further details regarding how they have it setup.
Just a FYI @David Kozuchar - were you aware that Bluebeam Stapler removes the digital signature from previously signed documents from Notarius / Consign-O?
When I am working with multiple pdf files, I have to extend one or more files to the second monitor. When a pdf is brought to the second monitor, the Bluebeam ribbon and menus will not go along with it to the second monitor and I will always have to select the tools from the original bluebeam window in the fist monitor. In…
Is it possible to extract data from multiple pre-defined locations on hundreds of scanned PDF's and extract/export to excel? Scanned pdf's would have same form and locations of information. I have been able to extract all of information on pages (creates mess) but no way to capture just certain fields/locations?
Good Morning Has anyone successfully imported their take-off from Bluebeam via excel into Trimble Contract Master Estimation software and have you managed to link an item in that take off to your database item?
Please correct me if I'm posting in the wrong spot: I had slow 2D rendering on a Lenovo P15 Gen 1 on several versions up to 21.6, then 21.6.1 seemed to fix the issue. With 21.8, the issue has returned. The usual 2D render settings have no effect on the behavior (it's as if it's stuck on iterative draw). Paging through PDFs…
Can someone please help with what seems to be a very simple question. I've turned off the "Snap to Content" button but my measurement tool still wants to snap. Every snap button is turned off. Grid is turned off. I just can't figure it out. Can someone help?
How do I compare worded documents? I believe my scale is off and it's highlighting the entire document but I'm not sure.
Hi, I would like to request assistance regarding an issue with a specific PDF file. The file was created using Foxit Editor, and I am currently using the latest licensed version of Bluebeam Revu. When I open the file in Bluebeam, all pages appear blank. However, the file displays correctly when opened in Foxit or Adobe…
This seem to be a new issue for me on V21.7. I can barely read the comment text within the Markup List. Any way I can change the display size?
Can someone please tell me why I suddenly can't access my tools or properties of tools in Bluebeam? I am trying to add my signature as I do every day but today all of a sudden, my saved tool set doesn't work. I can import a new signature .png to Bluebeam but it won't let me access the properties of the tool to change the…
