Is there a way to apply multiple digital signatures to a document without having to Save after each signature?
Isn't that how Batch > Sign & Seal works? (need Revu Complete). Also helps to increase Preferences > Tools > Signature > Password Timeout.
That would assume that the signature is in the same location on every page. I am usually dealing with contract documents and invoices that require signatures on some, but not all pages, and the location on the page varies.
If you could do that, wouldn't it mess with the integrity of the signature? They have a time stamp attached to them, and if the document has an edit time that differs from the signature, wouldn't that make the whole thing look suspicious?
I am not sure how that would be an issue. As it is, each signature has its own stamp and is saved each time they are applied. I often have to apply 4 or 5 signatures in the same document, so each time I am currently signing, the file gets saved. I was just looking for a way to get around the intermediate save steps.
On the projects where we have dealt with something of that nature, we create signature field templates and gathered signatures using Consigno software by Notarius. I wish Bluebeam had an equivalent capability.
Is there a way to batch hyperlink a range of pages instead of the entire document? I have a 325 page document. Within that document are sets. There is an overall page with area references to that set. That set is page 58-78. I know I could pull the set out and do it, then reinsert. Just wondering if there was an easier way.
