I want to group all WF Beams so when I click the beam for a take off it, has a pulldown to select the size. Can this be done?
This should be a product request. I really am disappointed they have not implemented dynamic blocks in Bluebeam.
Can you explain what you mean by dynamic blocks?
In AutoCAD you can define a block with parametric parameters to drop into a file, it would come in matching the drawing scale, and then you could stretch it to the dimensions you want, click drop down options to switch between different types, or create an array with an input amount of objects. So for example a single button would drop in an anchor and you could switch between cast-in, wedge, epoxy, screw, undercut, then stretch it to the length and change the diameter all with the same dynamic block. You would only need one toolbox button for all the different sizes and types of a particular thing. One single block for every type of steel wide flange beam. One single block for every type of metal deck. etc.
Can you explain in a bit more detail what you are trying to do - what is the step-by-step process?
This morning one of my coworkers opened a file that he has been performing a material takeoff in to find the original PDF content missing. All of his markups are present, but the background PDF content is not visible. He is running Revu 21.8 I opened the file on my machine (Running Revu 21.6) and have the same issue. I…
Is there any way to have a custom column property show up in a label?
Do markups on an offline iPad "time out" if the device doesn't connect to Studio in a certain amount of time? One of our employees was at a jobsite using Bluebeam on an iPad to add markups to a Studio Session (offline, no Wifi connection). A couple days later when the iPad was back online, the markups were gone. Is this…
Hi, been using Revu for a few months every day of the work week all day. I've been struggling with the legend. I set up the legend as i wanted it got everything working and put it in a toolchest. The first day it worked great, but every day since I have to keep setting all of my toolchests to use this legend as the…
Hi All, I need to send a share link of the Revised Arch. sheets in my Set to the printer. BB AI chatbot pointed me to Sets/Publish/Combine then select the option to "include only revised sheets". Sadly this option doesn't exist in my Combine window. Can anyone tell me where to find it or if there is another way to create…
I am opening Revu 20.3 extreme. It opens however it does not allow me to perform any functions. I have uninstalled and reinstalled it. Same issue. When i open revu 20.3, the window that says recover unsaved changes opens in the middle of the software screen. The item that it refers to was deleted from my pc. I also deleted…
I recently build a testing report for my field representatives that includes a javascript for some basic calculations. I wanted the form as easy as possible for my older field reps so I wrote a straightforward javascript that will automatically highlight, make bold, and show the result they are after. This form works…
Besteht die Möglichkeit, wenn ich die Deckenfläche markiere /ausmesse, dass gleichzeitig der Umfang angezeigt wird. Es ist doch erheblich aufweniger, wenn ich zuerst die Deckenfläche markiere und die m2 erhalte und dann nochmals die gleiche Deckenfläche abklicke um den Umfang des Randprofiles zu erhalten. Das könnte man…
How do I export all pdfs into one? I am going in a field visit tomorrow and I am trying to use a revu project in the field.
