When the line thickness of the call-out is set to 0, there is no box around the text and the arrow has a line thickness of 1.0. Is there any way of reducing the line thickness of the arrow without creating a box around the text?
Controlling the arrow and box separately would be nice.
oh yes!! This would be a nice enhancement.
This is needed — sloppy design that needs to be fixed!
Kicking off the new year Bluebeam has eliminated the iOS version of the Revu app, so now we are stuck with cloud. Cloud seems to have less than 25% of the functions we used on the app, and are now faced with cancelling several subscriptions due to the lack of tools. Primarily we use the Toolset in the field, on tablets. We…
How can I get this brown help suggestion box to stop popping up when I go to hyperlink? Every time I switch from document to document it lowers the page, and when I click to the next it moves the windows around just enough that I have to realign where I was hyperlinking to. Its very distracting and slows down work. I have…
Any time I create something in Bluebeam and open in AI it does not show anything. Anyway to make this happen.
On older version: When the measurement scale wasn’t set on a PDF, adding a measurement markup used to trigger a prompt asking me to set the scale first. In the newer version of Bluebeam, that prompt no longer appears, and the measurement markup disappears. Now, I have to set the measurement scale before adding any…
We just bought Revu 21 licenses for our office, and we have one user who has been using it for some time on Revu 20 Standard. I've been reading through the documentation and I believe I understand what our options are but wanted to make sure. I've got our licenses distributed through the admin portal for Revu 21, and am…
Windows 11, Revu 21.08.0.13613 I have a mouse with the forward and back buttons. I use LogiOptions+ to have the buttons do a keyboard shortcut only when using Bluebeam. Specifically, I make them do CTRL+Left/Right to go to the previous/next page of the pdf instead of the default of next/last view. This worked fine for the…
I'm trying to establish a workflow for adding multiple engineers' signatures and seals to different sheets of a single pdf drawing package. Example: I have three sections to my plan set which is required to be submitted as a single PDF. Civil, Structural, Electrical. Each of the three sections must be sealed by a different…
Good afternoon, I'm dealing with plans where every page is a differant scale. When I switch the scale on a differant page, it changes qunatities for all pages. I tried using viewports but it won't show me the total rollup on the bottom of the whole project. Any ideas? Thank you!
Is there a way to view two open PDFs side-by-side, at once? If there is, I can't find it. TIA!
Does the Mark-up Tools availabilty lag after renewal?
