I have a black PDF piping diagram and want to colour all the different types of pipes. Eg potable water = Blue, RO water = red, Sewer = green. How do I do this please.
I think I need some more information to answer that. can you provide a screen shot?
@Deano, If I understand correctly, it seems like you have a drawing with the piping diagrams already laid out, in black. What you are looking to do is change the colors of some lines to reflect your schedule.
The easiest way is to simply draw over those lines using the polyline tool, with the correct color. See sample below.
If you want to get fancier, you can also use "line styles" to include text on the line.
That's just what I wanted Shaya. I have only just downloaded the program so now I need to find the polyline tool and have a play.
@Deano, WELCOME!
This may help you find the polyline tool…
Pro Tip: Check out Bluebeam University - So much to learn there:
https://university.bluebeam.com/
Much luck!
Legend thanks.
Welcome to the #BluebeamSupportSeries! As part of our Bluebeam Support Series, we’re highlighting some of the most common questions and issues our Support Team has recently seen. Today’s post focuses on: Revu showing as Unpaid or Unassigned, where markup tools and other functions appear grayed out. A member of the Bluebeam…
Welcome to the second day of the #BluebeamSupportSeries! As part of our Bluebeam Support Series, we’re highlighting some of the most common questions and issues our Support Team has recently seen. Today’s post focuses on: Users not receiving their password reset or validation emails. A member of the Bluebeam team will be…
Welcome to the fourth day of the #BluebeamSupportSeries! As part of our Bluebeam Support Series, we’re highlighting some of the most common questions and issues our Support Team has recently seen. Today’s post focuses on: Error "There was a problem processing your request" within the Org Admin Portal. A member of the…
Welcome to the third day of the #BluebeamSupportSeries! As part of our Bluebeam Support Series, we’re highlighting some of the most common questions and issues our Support Team has recently seen. Today’s post focuses on: Reactivating deactivated users within the Org Admin portal. A member of the Bluebeam team will be…
With the new Bluebeam Cloud app, many of my foreman have switched from the old Revu app to this, and have requested a sorting feature. Right now it's only showing their jobs in numberic/alphabetic order. When we label our jobs, they get the job number first. So the most recent jobs are at the very bottom of the list. If…
It would be really helpful to be able to add layers AFTER a bluebeam session has been initiated. We use the layers to assign markups to particular users, which then allows them to filter their tasks.
I should be able to post a link here and have it take you to a Bluebeam session and a specific file within it. http:// (session URL) / file I should be able to link to a markup even as well. Why isn't this in Bluebeam yet? It's so frustrating that we (in multiple workplaces I've been at) have to say "hey folks we posted…
You can create Layer Configurations to control the layers within a PDF but that must be done manually for each PDF currently. I would like a way to import and export these configurations. I have thousands of layers, so doing this manually is not feasible. Ideally, I would like a human readable / editable format (such as…
I’ve noticed that in Revu 21, every page in the Thumbnails panel now shows “Scale: Not Set” if the PDF doesn’t have a defined drawing scale. In my case, I review and organize a lot of documents like submittals, wiring diagrams, proposals, and building maps, none of which use or need scales. The problem is that the “Scale:…
Hi, I have a question regarding the "recover unsaved changes" window. In this window, there is a "recover" button but whatever I do, it always stay "unclickable". What is this button for? I have always been confused by this window because I thought I would have to select the files and click on "recover" but in fact, we…
