You can create Layer Configurations to control the layers within a PDF but that must be done manually for each PDF currently. I would like a way to import and export these configurations.
I have thousands of layers, so doing this manually is not feasible. Ideally, I would like a human readable / editable format (such as CSV or XML) for the import / export format. This will allow me to write a script to create this file from my resources as things change and then easily import it into a PDF.
