I am a consultant and at a company I work with they have multiple projects contained within a Revit model. They use Collections within revit to be able to organize same named sheets that are standards driven for sequencing IDs. When attempting to utilize the Bluebeam "Add-In" print settings you are unable to see Collections as a choice. I am limited to seeing just the sheet names which in turn is duplicate ID's but I cannot determine for which project ID it has been set to within. I am able to use Collections as a feature selection within Revit and they also use a tool called RTV tools to easily manage Collections and sheets for mass printing. The Bluebeam Add0-in is desired for the Max capabilities but not being able to to drill into the defined Collection is a problem, If we are to use the benefits of Max and the integration to Revit for printing and default scaling of views or markup linking is there a way the Bluebeam team can add Collections as well that is contained within the BB Revu Add-in for Revit?
