Hello,
Please see attached. I am doing a rebar takeoff. I have a footing that is not squared. I have used multiply option to multiply my rebar lines spaced equally. however as you can see I have to adjust each line into the footing shape. Can you please create an option that I can trim all lines at the direction i want at once similar to CAD? doing this one at a time is excessively time consuming. and Hatch wont work in this case since I am calculating the line quantities and lengths. it took me like 15 minutes to shorten the lengths of these lines one by one.
There is no easy "trim" option that you could use.
