Is there a way to list all markups made since the last file save?
In the Markup List you can use two date columns - Creation Date and Date.
The Date column updates every time a change is made to a Mark Up. So, you can just sort or filter this column to see which mark ups have been created or updated since your last save (you'll have to get the details from Windows Explorer for this).
If you just want to look at which new Mark Ups have been newly added then use the Creation Date column.
Vince - you saved the day!
Thanks
Is there a way to batch hyperlink a range of pages instead of the entire document? I have a 325 page document. Within that document are sets. There is an overall page with area references to that set. That set is page 58-78. I know I could pull the set out and do it, then reinsert. Just wondering if there was an easier way.
Are we ever going to be able to edit a user email address in Org Admin? I know this has been discussed before and was a topic at Unbound last year. I have heard nothing about it since. This may not be a frequent issue, but it has come up several times now with users who have changed their last name. Our organization email…
Error when clipping polygons. Original control points (vertices) that lie outside the clipping extent either disappear or are displaced. Does anyone experience this?
I crossed out a text, however, I need to remove that cross out line (not the text). Could someone let me know how to remove the strikethrough?
I've customized the callout tool for weld mapping (O&G fabrication). I have the line, endpoint, and text box shape as I like them. My problem is, when used in drawing mode, my pre-populated text and text box size is exactly how I want it but the line endpoint and associated lines are locked in place (not ideal). If I use…
How do I select multiple mark-ups and copy them to all sheets in the PDF?
Help! I need to open AutoCAD files and can't find the basic instructions to find and install the plugin that will enable me to open, mark up, and save native dwg format files into a new pdf markup. I opened 'Administrator' but can't find the option to install a new plugin to Bluebeam. I only have Excel and Word plugins,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad?
