We have callout tool set up with certain size of leader. Sometimes, I started with text box tool and need to add a leader later. The default leader size shows quite big. The font size is actually the same, just callout tool setting is 50% of the font size while the text box setting is auto. I can fix it. But I want to set it as default so I do not need to manually fix the leader every time. It just won't stay. Any solutions? Thank you.
