Is there a way to delete all layers from all pages of a multi-page document in a single action? I can only see how to do it one page at a time.
@Ross I have found that if you combine files, it can remove all layers in the new file. The following steps may help save some time.
4. Make sure that merge layers is not checked.
5. Select add open files and ok.
6. Delete the blank page from the new combined file and save it.
The new file will have no layers, and you can use the same blank document over and over for this purpose.
This depends on how the layers were created. If you have combined a file made up of pages that already had layers on them and transferred those layers into the combined file, they will be grayed out on the layers panel when you aren't on the same page/pages they transferred over with.
If, however, you created the layers on an already-multipage document, those layers should already work globally. So, if you delete one layer, it would delete from all pages it was on. Additionally, if you wanted to grab all the pages at once, you should be able to use Shift or CTRL to highlight multiple layers at once and then choose to delete. This would theoretically delete those selected layers from all pages in one swoop (especially if you checked all the boxes from the pop-up that appears when deleting layers.
Ashley, thanks, this is somewhat helpful, but not exactly what I was hoping for.
I get pdf files of multiple sheets from people who printed them out of e.g. Autodesk applications. It's very common in our office, and I also get from external Project consultants. But I'm often the one who has to manage & collate different pdf files, most of them having layers, and before submittals — delete the layers because permitting agencies reviewers don't work with files having layers.
So, rather than trying to coach & educate multiple people contributing to the project about the way they print from their various Autodesk applications, it'd be just easier if I could easily delete all layers from any multipage document, in one stroke.
For instance, here's the layers in one sheet of a 45 sheet set…
And here's the layers in another sheet of the same set..
(there's still more than shown). That's the same person printing — she's printing the same way. It's just evident that that the Autodesk files are "accumulating more "stuff" all the time, and that stuff leads to more layers.
So I think you see from the above my problem is that in a document with say 10 or 50 pages, with layering like this, the layers seem infinite, & being able to delete one specific layer from all sheets at one time, isn't quite working for me. I guess my term "globally" that I used initially might not have been the right terminology.
Again, rather trying to control the way that various people print to pdf's, it'd be easier if I could easily delete all layers in one go.
Thanks
Thanks Glynis D.! Good & easy work around.
One of our reviewers is having a problem that pops up randomly. The problem that happens is as follows and is totally random and occurs when reviewing any session(s): Extracting sheets with comments, pasting images, and details in various sheets. Once pasted images and text has been added to various sheets the reviewer…
Every Time I load a document, it says this document has a protected scale and won't let me measure anything. Anyone have any suggestions. Thanks
Hi, just wondering how I can edit markups/takeoffs that I made at my home office and view and change at my work office? Any help would be appreciated. Thanks.
Not sure if there is an option to upgrade my purchase , as i purchase the basic one but need core because i need to measure perimeter and more advanced tools etc.. ? Anyone know if its possible to upgrade and how ?
Where did the default page navigation arrows go? How do we get Revu to go back to the default page navigation interface? What did we do to make this change to the Revu UI? Default UI Current UI
Hi everyone, I am a Building Surveyor and use bluebeam when I'm undertaking audits of existing buildings that are later put into Building Code reports. The system is amazing for what I do, but just generally I need to put photos into emails and reports where its easier to just grab the photo and put into our reports…
Dynamic Fill is an awesome tool, but from time to time I do try to use i on drawings where even though I have an outline shape that appears to be closed, the Paint Bucket tool still bleeds out even at the smallest brush and slowest fill settings. Does anyone have any suggestions or found a fix for this? Using it primarily…
Hi, I want to use the textbox markup to type in the Farsi language, but it shows separated and backward. How can I fix this issue?
Hello, I'm looking for a 3-party System/Vendor that we can use to backup the entirety of our Studio contents (across all Users/Projects). One that an BB Admin could use that allows visibility of all Users/Projects/Data/Folders/Files being stored under our Company/Licenses; and simply be able to backup everything from the…
