Please improve the Rotate function when rotating with the grip on plan. It has like a 15° resolution. Please make it more granular / smoother.
Hello,
If I understand your question correctly, you want to make a rotation at 15 degrees? This is possible if you hold down the shift key. Then any desired degrees can be determined. Without a shift key it is at 0, 45, 90 and so on.
Is this what you mean?
I think the question is the opposite - being able to rotate to any degree without it feeling like it "clicks" or "locks" at certain intervals.
If you hold down shift, you can rotate freely to much more granular angles
With me it is the other way around. the standard is free rotate and if i want to draw in 45 or 90 angles i have to use the shift key.However i dont know how to undo this option. I use mostly 45 and 90 degree angles. Is this an option in the menu perhaps?
I think it would be useful to have a tool to mark several/all pages in a PDF with a watermark. In my specific case, I'm trying to note that a specification in a project manual still needs updates, but to do so in a manner that looks polished and professional. If a tool like this already exists, it would be useful if it…
Our IT department has been slowly upgrading our users to Windows 11. A few of our users have been experiencing really bad lag with creating, moving, modifying markups. This happens both in Session and with locally saved files. It seems to only be happening to our users with virtual/cloud computers. Specifically, we use…
Hi All, I accidentally added a layer at the end of the long list of existing layers. Has anyone found a way to reorder the layer list? I would also like to hide one of the layers I created by default and open it only when I need it. Is this possible? Thank you ahead, Ian
Effectively a transmittal listing the names of the sheets printed in a given PDF print operation. Automatically generated, probably toggled on & off with an additional checkbox option in the print dialog.
I'd like to see a tool where you can magnify part of document/drawing/detail/etc via callout or simple shape on a drawing. See video below for SolidWorks and Apple Photos examples. Option 1 How to add Magnifying Glass or Details view in SolidWorks Drawings Option 2 iPhone 14/14 Pro Max: How to Zoom In or Magnify Part Of A…
Everytime i start a new pdf the first thing I have to do i change it to Fit to Page so I can see the whole pdf.
Revu is powerful, but lacks the ability to configure/save Workspaces for specific tasks. As example: Markups The native dock location (bottom) for Markups is not very user friendly. Yes, I can drag it out and position on the side, so I can still see our 24x36 (ARCH D) engineering plan sheets, but it has several issues.…
Dynamic Fill is an awesome tool, but from time to time I do try to use i on drawings where even though I have an outline shape that appears to be closed, the Paint Bucket tool still bleeds out even at the smallest brush and slowest fill settings. Does anyone have any suggestions or found a fix for this? Using it primarily…
Hi, we mainly use Revu 21 to edit pdfs and save in PDF/A format. We need pdf documents in PDF/A-2b format. Is it possible to convert a pdf to pdf/A-2b format? please explain how to do it? thanks Oliver
