Snapshot tool - keeps using the old snapshot
Snapshot tool - keeps using the old snapshot. When I create a new snapshot and try to paste it, the old one shows up again. Tried saving and closing, no luck. Tried clearing the windows clipboard, then I couldn't even paste. New problem just popped up overnight. Revue 21.6.10194, can't upgrade until it we get the trickle…
Sets
How do I figure out what the uncompleted actions are?
PDF content disappeared overnight
This morning one of my coworkers opened a file that he has been performing a material takeoff in to find the original PDF content missing. All of his markups are present, but the background PDF content is not visible. He is running Revu 21.8 I opened the file on my machine (Running Revu 21.6) and have the same issue. I…
Pre populated Custom Columns
Is there any way to have a custom column property show up in a label?
Markups disappear when using Bluebeam on iPad offline?
Do markups on an offline iPad "time out" if the device doesn't connect to Studio in a certain amount of time? One of our employees was at a jobsite using Bluebeam on an iPad to add markups to a Studio Session (offline, no Wifi connection). A couple days later when the iPad was back online, the markups were gone. Is this…
Legend Presets not holding
Hi, been using Revu for a few months every day of the work week all day. I've been struggling with the legend. I set up the legend as i wanted it got everything working and put it in a toolchest. The first day it worked great, but every day since I have to keep setting all of my toolchests to use this legend as the…
How to create a share link to just the revised sheets in my Set
Hi All, I need to send a share link of the Revised Arch. sheets in my Set to the printer. BB AI chatbot pointed me to Sets/Publish/Combine then select the option to "include only revised sheets". Sadly this option doesn't exist in my Combine window. Can anyone tell me where to find it or if there is another way to create…
Recovery and Revu 20 opens but will not allow any functions.
I am opening Revu 20.3 extreme. It opens however it does not allow me to perform any functions. I have uninstalled and reinstalled it. Same issue. When i open revu 20.3, the window that says recover unsaved changes opens in the middle of the software screen. The item that it refers to was deleted from my pc. I also deleted…
BB Cloud doesn't have a Forms field or support javascript it seems
I recently build a testing report for my field representatives that includes a javascript for some basic calculations. I wanted the form as easy as possible for my older field reps so I wrote a straightforward javascript that will automatically highlight, make bold, and show the result they are after. This form works…
Umfang gleichzeitig mit der Fläche
Besteht die Möglichkeit, wenn ich die Deckenfläche markiere /ausmesse, dass gleichzeitig der Umfang angezeigt wird. Es ist doch erheblich aufweniger, wenn ich zuerst die Deckenfläche markiere und die m2 erhalte und dann nochmals die gleiche Deckenfläche abklicke um den Umfang des Randprofiles zu erhalten. Das könnte man…
