A mirror tool would be really helpful when sketching ideas.
There is the Alignment > Flip Horizontal / Vertical tool. You'll have to group the markups first, and it doesn't always work perfectly. It would be nice to have a more robust mirror tool that leaves the original markup, and an option to group the result after mirroring.
I use this workflow….Group the first markup, then copy. Now flip the new markup and ungroup both.
It would also be nice to have a tool that doesn't reset your layers if your markups belong to different ones.
I have been having issue with my Bluebeam/Revu that prevents me from carrying on with my work. Sometimes when a file is open and in the middle of working with the file, the following message pops up (see snippet below), which locks me out of continuing the work and forcing me to "End program" and restart Revu again. This…
Does anyone know if there is a quick way (or any way) to do a bulk 'Find & Replace' on a markup? For example, I have x number of yellow widgets on a markup but the specification changes and I need to replace all the yellow ones with red ones instead. I want to be able to tell Revu to find all the yellow widgets, delete…
Hi everyone, I’ve been working with Bluebeam Revu for different construction projects, and while it’s been a great tool overall, I still run into a few challenges that I’d like to improve on. For example, scaling drawings accurately can sometimes be tricky when dimensions aren’t clear, and managing markups across larger…
As I understand it, Revu for iOS will be removed from the App Store at the end of this year. Users are recommended to use Cloud instead, which imo hasn’t caught up with Revu for iOS, yet. Furthermore Revu for iOS could be used by users for editing in Studio Project without a subscription. Will Cloud also support this? I’m…
I would like to know if there is a way to search throughout a file or set to references a detail on a page? In other words, I want to do a reverse search from a fine detail, all the way up the drawings.
In the past month or so, bluebeam has been crashing when editing text boxes. Doesn't always happen, but this is extremely frustrating. It's also been buggy with properties menus disappearing or showing properties for a markup that I didn't select.
Hi All, I have single PDFs of my Arch., Struc. and Civil drawings. I would like to Slip Sheet new revisions of individual sheets into these plans separately and still have access to the previous revision's sheets. Is this best done through Sets or is there another way. Sets seems to be used to combine single PDFs into…
So , my question is that i'm noticing that the tools in the toolchest will automaticly rearange themselves in a surtain order. I believe only a few updates back this was not the case or a lot less. I could be mistaken as i,m still a relatively new user. Is it not possible to keep your tool in a surtain order and they dont…
I see that there is a ellipse tool, but is there an actual circle tool? If so, where is it?
Is there a way to have an option to include the page number as a prefix when selecting a page region for label? Only ask for this because I often will create page labels based on page region but it would be nice to include a method of retaining the page number in the label for extraction as single sheets, the plans are in…
