I see that there is a ellipse tool, but is there an actual circle tool? If so, where is it?
Try holding shift as you draw the elipse - this should give you a perfect circle. Holding shift whilst using the rectangle tool will give you a perfect square.
Thank you Vince French….that worked perfectly.
Shift and Alt are secret support keys for lines, rectangles, circles and arcs. For an ellipse, holding the Alt key gives you a circle based on radius instead of…..y'know, the other way 😅
…just have to make a symmetrical ellipse.
How do you make a perfectly symmetrical ellipse? If I want a circle with for example a 2'-6" radius, how do you make that perfectly?
