I have added the checkbox from the 'FORMS' into my stamp, but when I add the stamp into the pdf, I can't check the boxes.
There is an article about creating interactive stamps. It's not too complicated once you get the hang of it, but getting started can be a bit slow. For my part, I used one of the predefined interactive stamps to adjust the design and fields to my needs instead of creating a completely new stamp from scratch.
If something didn't go as I envisioned, AI was able to help me fix the code.
https://support.bluebeam.com/revu/how-to/add-and-edit-interactive-stamps.html
We use the same arrangement for a submittal review stamp. Perhaps the same workflow applies.
Since the stamp tool applies a captured image, we have to edit the stamp for each application, changing the date, submittal (spec) section number, and edit the check boxes according to our status applied to the review, like APPROVED, APPROVED AS NOTED, REJECTED, etc.
This ensures the stamp is not editable and captures the record of our review before flattening.
So, summing up, rather than editing your stamp after placing/applying it in your PDF, edit AND SAVE the stamp before applying it.
Hi,
Were you able to add additional fields to the stamp? I'm currently working on customizing the engineering review stamp from the custom libraries, but I'm having trouble figuring out how to edit it without disabling the pop-up feature that appears when placing the stamp.
Ideally, I want the pop-up to remain active so that the reviewer can fill out the required fields immediately—without needing to edit or save the stamp beforehand.
Any guidance or suggestions would be greatly appreciated!
I am looking for the same idea.
Hello. I use LogMeIn to access my workstation remotely. LogMeIn disconnects randomly all the time. Whenever this happens, Bluebeam stops functioning. I'll have any number of PDFs open at once (up to 10 or more). I can still see the PDFs on screen but I have no ability to pan or zoom or use any tools. I have to close each…
Hello everyone! Can someone please tell me where the experts are on utilizing BB cloud on an iPhone in conjunction with their BB revu on their laptop! I have too many questions to ask here!🙄
I downloaded and installed the new version of Revu this morning and am not able to find this new feature. I see that applications to beta test are open, does that mean that this new feature is coming later if you are accepted for beta testing?
Recently updated to Revu 21, upon opening pdf documents, both manuals & drawings, tools on tool bar screen right are indicted "disabled". I opened Tools tab at page top and checked all tools, doesn't help. Any ideas ???
I have a PDF form created by a third-party. Every time I try adding my digital signature, the form turns black and illegible. Has anyone run in this? Any thoughts? I tried refilling the form and resigning, but it just happened a second time.
Just attended my first Tips & Tricks webinar earlier this week. It was great! Today I received an email from Stephanie with a link to watch an on-demand video. Unfortunately, I'm not able to visit the site (I receive an error message - see below)
Is there a tool which can apply a template to an existing PDF document? I can do it with the overlay tool, but its not efficient. I am currently specifically attempting to apply a letterhead to a PDF document without having to using snapshot, etc.
We were messing with settings now all the tools in my tool box are numbered and now I can't find the setting to get rid of the numbers next to the tools.
Long post for context: Yesterday I was trying to compare a revised architectural to realize that the floor plan has shifted in both the X and Y, so this morning I did a page snapshot. What I would like to know is, is there a way to snap to a point on the snapshot and move it to a point on the drawing?
