Is there a tool which can apply a template to an existing PDF document? I can do it with the overlay tool, but its not efficient.
I am currently specifically attempting to apply a letterhead to a PDF document without having to using snapshot, etc.
Depending on what the letterhead looks like, you might be able to mimic the effect using the Header & Footer feature for the text and the Apply to Pages feature for any logos or images.
the document is a corporate letterhead in PDF form which i want to apply to existing PDFs.
I believe you can simply create one and then apply it when necessary.
You could make a simple markup tool with an image of the letterhead @Gregt.
Steps:
The next time you want to apply the letterhead simply select the image from your toolchest and place it where needed. You may want to flatten the image so that others cannot remove it…
Hope this helps! 😎
Are you asking about a "watermark" feature?
I was also thinking you could create a custom Stamp with your letterhead and you can create different layout for th∈ different page sizes you would be using.
